Force use of wireless, not wired network connection.
I use a Windows XP laptop at work that has wired & wireless ethernet connections. The wireless connection allows access to the internet but not my company's LAN, and the wired ethernet connects to the LAN. Is it possible to force my laptop, or just a specific browser like Firefox to connect to the internet using only the wireless connection?
Currently, whenever I plug in the ethernet cable or enable the ethernet conneciton, I lose my wireless internet connectivity. I do need to be connected to the company lan while I use the wireless network for internet access. Is it possible to use one nic for the internet and one for access to the LAN?
Both nic's are assigned by DHCP, so I don't think I can mess with their default gateways. I've already gone into ncpa.cpl and opened the "Advanced Settings" menu to make sure my wireless network is at the top of the list of connections.
I'd appreciate any help offered. I've listed the results of ipconfig /all and route print below
-Mike
[cpp]
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6205
Physical Address. . . . . . . . . : A0-88-B4-91-E7-58
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.200.123
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.200.1
DHCP Server . . . . . . . . . . . : 1.1.1.2
DNS Servers . . . . . . . . . . . : 69.145.248.4
69.146.17.3
69.146.17.2
Lease Obtained. . . . . . . . . . : Thursday, December 08, 2011 11:03:31 AM
Lease Expires . . . . . . . . . . : Thursday, December 08, 2011 12:03:31 PM
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : xxxx.yyyyy.net
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection
Physical Address. . . . . . . . . : 2C-41-38-0C-4F-BD
IP Address. . . . . . . . . . . . : 10.20.11.248
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 10.20.1.1
DHCP Server . . . . . . . . . . . : 10.20.1.107
DNS Servers . . . . . . . . . . . : 10.20.1.102
10.20.1.107
Lease Obtained. . . . . . . . . . : Wednesday, December 07, 2011 11:00:22 PM
Lease Expires . . . . . . . . . . : Wednesday, December 14, 2011 11:00:22 PM
[/cpp]
[cpp]
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...a0 88 b4 91 e7 58 ...... Intel(R) Centrino(R) Advanced-N 6205 - Packet Scheduler Miniport
0x3 ...2c 41 38 0c 4f bd ...... Intel(R) 82579LM Gigabit Network Connection - Packet Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.20.1.1 10.20.11.248 20
0.0.0.0 0.0.0.0 192.168.200.1 192.168.200.123 25
10.20.0.0 255.255.0.0 10.20.11.248 10.20.11.248 20
10.20.11.248 255.255.255.255 127.0.0.1 127.0.0.1 20
10.255.255.255 255.255.255.255 10.20.11.248 10.20.11.248 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.200.0 255.255.255.0 192.168.200.123 192.168.200.123 25
192.168.200.123 255.255.255.255 127.0.0.1 127.0.0.1 25
192.168.200.255 255.255.255.255 192.168.200.123 192.168.200.123 25
224.0.0.0 240.0.0.0 10.20.11.248 10.20.11.248 20
224.0.0.0 240.0.0.0 192.168.200.123 192.168.200.123 25
255.255.255.255 255.255.255.255 10.20.11.248 10.20.11.248 1
255.255.255.255 255.255.255.255 192.168.200.123 192.168.200.123 1
Default Gateway: 10.20.1.1
Persistent Routes:
None
[/cpp]
2 answers Last reply
More about force wireless wired network connection
  1. I believe the problem is that you have TWO default gateways (0.0.0.0), but the one w/ the higher priority (192.168.200.1) also has a higher metric (meaning, the longer route), so Windows is always choosing the LAN gateway (10.20.1.1) w/ the shorter route (despite having a lower priority). You need to insure the gateway you want to use has the lower metric (or at least the same metric, presumably Windows will then honor the priority).
  2. for security reasons your company might not want you to be able to have access to the internet while connected to the network.
    talk to IT to receive approval and have them set it up, otherwise it could be a cause for termination
    my company fired two people that played around with the computer settings in that manner
LAN Wireless Network Connection Ethernet Card Networking
