S speedstur Honorable Dec 15, 2012 9 0 10,510 Dec 20, 2012 #1 http://www.bestbuy.com/site/Dynex%26%23153%3B+-+400-Watt+ATX+CPU+Power+Supply/8311052.p?id=1174091945952&skuId=8311052&st=psu&cp=1&lp=8
J johnsonjohnson Honorable Dec 15, 2012 779 0 11,160 Dec 20, 2012 #2 It might but I don't think you should get it. I recommend this one instead. It usually go on sale for even less if you're willing to wait. Corsair CX430 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026 Upvote 0 Downvote
lunyone Splendid Feb 22, 2006 6,517 0 26,960 Dec 20, 2012 #3 I personally wouldn't buy and Dynex product, but here is what I'd recommend for a budget PSU that would work fine for your needs: Antec VP-450 450 Watt Energy Star Certified Power Supply Comes with a 2 yr. warranty (the Dynex has only a 1 yr. warranty) and is only $39 shipped! Upvote 0 Downvote
camohanna Distinguished Oct 21, 2012 1,789 0 20,160 Dec 20, 2012 #4 Any of the ones listed above will do fine. Any Antec, corsair etc will be good. Look for the 80 plus efficiency rating and get as high as possible. Upvote 0 Downvote
