Lunyone's "I just need a bit more speed than a Budget friendly Build!"
Upgraded parts from original "Budget Build" that I posted before, are:
* CPU upgraded a bit
* HD upgraded to SSD!
* GPU upgraded a little over a step up!
* PSU upgraded to handle more GPU power!
Gaming build on a more affluent budget!
CPU: Intel Core i3-3220 3.3GHz Dual-Core Processor ($125.99 @ Amazon)
Motherboard: ASRock Z77 Pro3 ATX LGA1155 Motherboard ($89.99 @ Amazon)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($41.99 @ Newegg)
Storage: Samsung 840 Series 250GB 2.5" Solid State Disk ($179.73 @ Amazon)
Video Card: HIS Radeon HD 7870 2GB Video Card ($214.98 @ Newegg)
Case: Rosewill REDBONE U3 ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Rosewill Hive 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($59.49 @ Amazon)
Optical Drive: Sony AD-7280S-0B DVD/CD Writer ($18.99 @ Newegg)
Total: $781.15
* CPU is one of the best in this price range and performs quite well in gaming!
* Mobo has onboard USB 3.0 ports, to take advantage of the Front USB 3.0 ports on the case listed!
* RAM runs at stock voltage of 1.5V's and at 1600 mHz speed @ CAS 9!
* SSD is one of the faster ones out there and also has quite a bit of room for several games and applications (at 250 gb's of space before format and Windows install). This will keep things snappy in and around Windows!
* One of the better GPU's for the $/perfomance out there! Hard to beat around this price range!
* Case has 3 x 120 mm fans INCLUDED! and also comes with 2 x USB 3.0 front ports! Most cases around this price range only include 1 or 2 fans and most don't have front USB 3.0 ports!
* PSU is 80 + Bronze Certified at 40 degrees C!!! Also is modular, keeps cable clutter down and airflow up! Has 38A on the 12v rail and comes w/1 x 6 pin & 1 x 6+2 pin PCI-e power connectors for any single GPU out there!
So there you have it! Gaming on a Moderate budget build!
You can find this build on Page 3 of the Best Configs: Budget Intel gaming build
Here.
* You can drop the SSD and install a 320 gb - 1 TB HD instead for about $50-80 and save ~$100.
* You can drop the GPU down to a 7850 2 gb and save about $30-50 over the 7870 listed.
