Are these parts compatible with each other? [First Time]
Hi, I want to build a new desktop computer. I have never built a computer before and I just wondered if these parts are all compatible with eachother. :) If you can help me I will be most thankfull!
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
ASUS P8Z68-V/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
SAPPHIRE Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card (11192-22-20G)
RAIDMAX HYBRID 2 RX-530SS 530W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Power Supply
Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32100
OCZ Vertex 3 VTX3-25SAT3-60G 2.5" 60GB SATA III MLC Internal Solid State Drive (SSD)
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
Western Digital WD Blue WD2500AAKX 250GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SONY Black SATA DVD-ROM Drive Model DDU1681S-0B - OEM
4 answers Last reply
More about parts compatible other first time
  1. I'd change fewa things in this build, but i need more info from you please fill out those questions, otherwise it's gonna take too long asking you those question one by one. Post answers here. After you do that we will be able to help you faster, without having to be guessing in the dark. Thanks
    http://www.tomshardware.co.uk/forum/353572-13-build-upgrade-advice
  2. Personally, i'd suggest going with a larger SSD. Almost everybody now recommends 120gb minimum.
  3. That power supply is one of the worst in the industry. There's also no need to get a Z68 board with an i3-2100 since you can't overclock. What is your budget? I would suggest a different build.
  4. Ok, thanks for replies :) My budget is around 600 dollars, and I don't really want to go higher than that. I'm considering upgrading it later, since I really wanna do this just to build a computer that works and can run some games and programs at atleast medium settings.
    I already have a monitor, so It's just the build that I am focusing on. I also have a OS (Windows 7 Home Premium), so that's out of the way.
    I buy my parts from newegg solely since their warranties are pretty good.
    I prefer Intel processors and motherboards, that's why I'm going with the i3, because it's cheaper but still a good processor.
    I am not planning to Overclock.
    My Monitor is 1920x1800. The graphics card I chose doesn't support that resolution, so I plan to upgrade it later to a card that supports it.
    Lastly, I'm wondering how powerful my Power Supply has to be :) Thanks!
New Build Systems
