Archived from groups: alt.video.laserdisc (More info?)
Hi, i live in the Netherlands, have the Pioneer cld1850 LaserDisc
player, is there a "kit" to make my player play the (analog) sound of
my PAL LaserVision discs ? or should i buy a secondhand player that
does the job ? (if cheaper) Please help !
"Tribal" <not@real.domain> wrote in message
news:9jn9b0hch7lrk30lh8lc3v4vv9mis5di9k@4ax.com...
> Eric.
For 106 UK-pound you better try to find a CLD925 player (both side player
and Ac3 output).
If you don't care for AC-3 output you could also try to buy a CLD2950 (both
side) or a CLD1950 (single side).
And if these models aren't available you are even better of buying a
CLD1750.
(and you can always add AC-3 output later when needed .... if you are handy
you could do it yourself.... schematics can be found on the net...google is
your friend)
The CLD1850/CLD2850 are the 'worst' PAL/NTSC players Pioneer made. Bad
picture quality (compared to the older models) and no PAL laservision audio.
Thank you Roy ! that's what i wanted to know,
i also still have a tray broken Philips 475, but repairing will
be also pretty expensive i guess....
On Wed, 26 May 2004 23:43:55 +0200, "roy" <deletethis@zonnet.nl>
>> Eric.
>Hi,
>There is a kit available (eg http://www.videotec.co.uk/ldmods.htm) but the
>price of 106 UK-pound is very high.
>The 1850 isn't 'worth' it.
>and Ac3 output).
>CLD1750.
>your friend)
>good luck,
>Roy
