Solved
No POST/Bios on fresh build/start
*Case - Ultra XBlaster Mid-Tower V2 Case - ATX, MicroATX, USB 2.0, Audio, 6x 3.5" Bays, 4x 5.25" Bays, 7x PCI Slots
*MB - MSI 760GM-P23 (FX) AMD Series Motherboard - Micro ATX, Socket AM3+, AMD 760G, 1333MHz DDR3, SATA II (3Gb/s), RAID, 7.1-CH Audio, Gigabit LAN, USB 2.0
*Processor - AMD FD4100WMGUSBX FX-4100 Processor - Quad Core, 8MB L3 Cache, 2MB L2 Cache, 3.60GHz (3.80GHz Max Turbo), Socket AM3+, 95W, Fan, Unlocked
*Ram - (2x) Kingston HyperX Red KHX16C9B1R/4 4GB Memory Module - 1600MHz, 9-9-9, DDR3, CL9, 1.65V, Unbuffered
*Optical - Lite-On IHAS124-04 Internal DVD Writer - DVD+R 24X, DVD-R 24X, DVD+RW 8X, DVD-RW 6X, DVD+R DL 8X, SATA (OEM)
*PS - Pixxo PL Series PL-500RPG 500W Power Supply - ATX, SATA and PCI-Express Ready, 80mm Cooling Fan, Short Circuit Protection
*Case Fan - Kingwin CFBL-012LB LED Case Fan - 120mm, Blue
I just put everything together. I am waiting for my Graphics card and a brand new 500g Drive and Win 7 cd to come in the mail. However, i have a 160g harddrive with a fresh install of Win XP that i hooked up just to see if the pc worked.
Here is the issue, when i power on, i get the one beep, and i get the MSI loadup screen. after that i get another MSI screen that says press any button to boot. When i press any button, I get another screen to select boot source. The only thing that shows up is the CD/DVD drive. The HD does not show up at all. I have tried unplugging the HD and replugging in different sata plugs but nothing. When i try to boot from the cd drive nothing happens. Says there is nothign to boot from and press any button to go back. I have tried with/without the MSI boot cd in the drive. Is there something i am doing wrong or do I need to wait for the new harddrive, card and new Win7 OS?
Pics
Harddrive/CD drive
http://img.photobucket.com/albums/v336/hotsniper/20121220_124908_zps139eb7fb.jpg
MB
http://img.photobucket.com/albums/v336/hotsniper/20121220_124903_zpsa0ebe6e8.jpg
First Screen
http://img.photobucket.com/albums/v336/hotsniper/20121220_124822_zps161c8441.jpg
Boot Screen
http://img.photobucket.com/albums/v336/hotsniper/20121220_124833_zps20ab946f.jpg
Boot Options Screen
http://img.photobucket.com/albums/v336/hotsniper/20121220_124841_zps74583d4a.jpg
Boot Error Screen
http://img.photobucket.com/albums/v336/hotsniper/20121220_124849_zps723839ce.jpg
7 answers Last reply Best Answer
More about post bios fresh build start
  1. If you go into the BIOS, does it show your HDD at all? If not, i'd say the drive is bad.
  2. cant get into the bios. The pics i provided are the only thing that i can get into. Press anybutton to boot, then it goes straight to the screen where it only shows my cd drive. This happens with/without the HD hooked up.
  3. Best answer
    You should be able to get into bios by pressing the delete key during post. Once in the bios look to see if you can see the hard drive.
    Does your hard drive spin up at all?
  4. what exactly do you mean POST. soonas it starts up? I get the one screen and then i get the press any button screen
  5. I wont be able to check it out til later tonight but i appreciate the help your giving. This is my first build and when i look in the manual on the motherboard it shows it going straight to the BIOS.
  6. Thanks for everyones help. The POST was actually the Logo screen for MSI. the default setting was to show that instead of the actual POST settings. Everything is running great.
  7. Best answer selected by kwassing.
New Build Systems
