Sign-in / Sign-up
Solved
My First Build with a few old parts
  • New Build
  • Computer
  • Systems
  • Product
Last response: in Systems
December 20, 2012 7:12:29 PM
I've been running an old computer that's about 6 years old and have replaced the power supply and upgraded the graphics twice. Now it's just completely outdated (with a Pentium D 2.66 GHz Processor) and I've decided to finally build a new computer. This is my first time building a computer, the one I have right now is a HP Pavilion a1606.
What I plan on reusing:
PSU Dynex DX-400WPS 400 Watt ATX PCIe SATA PC Power Supply
HDD WD2000JS Western Digital Caviar SE SATA II Hard Drive WD2000JS
What I want to do with the computer: Play games and simple school work with MS Office. I don't need settings to be any higher than medium really, key is to keep cost below $300-350. I would like to know if what I have so far is all compatible and the best option for the price.
Here is what I have picked out so far:
MOBO ASUS F2A55-M LK PLUS FM2 AMD A55 (Hudson D2) Micro ATX AMD Motherboard with UEFI BIOS
Case Rosewill FBM-01 Dual Fans MicroATX Mini Tower Computer Case
APU AMD A10-5800K Trinity 3.8GHz (4.2GHz Turbo) Socket FM2 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 7660D AD580KWOHJBOX
RAM Kingston HyperX XMP Blu Red Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model KHX16C9B1RK2/8X
I don't really plan on overclocking and will probably buy a graphics card down the line to hybrid crossfire with the APU. I plan on buying in about a week. All of this right now is about $300 with tax and s&h.
So that gives me a PSU, APU, Case, RAM, HDD, MOBO. I also have a disk drive that will probably work as well, but I don't know it's model nor do I particularly care if it works. I would like to be able to play games like Guild Wars 2, Metro 2033, Crusader Kings II at least on low settings with 20-30+ fps. Would this all work for a cheap computer upgrade? Thanks in advance!
More about : build parts
December 20, 2012 7:14:06 PM
Please don't just put hyperlinks in your post. List the make/model of each item so people can easily answer your post. Nobody is going to click on 6 different links to try and help you.
m
l
Best solution
December 20, 2012 7:32:27 PM
Gaming on an APU scales heavily with the RAM - get the fastest that your motherboard can take.
December 30, 2012 5:04:58 PM
Best answer selected by pxrx63.
m
l
