Burner drive not being read
Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
Hi,
My problem is that my DVD-R/CD-RW drive is not being
recognized in most of my programs. If I right click the
drive itself, it says that it is working finea nd that
windows recognizes it as a recording drive. However,
neither Media Player nor Nero notice recognize that there
is a drive. I have a Daemon tools virtual drive if that
makes a difference. Any help would be great, as I'd hate
to finally have a DVD drive and not be able to burn
movies.
Thanks for any help.
6 answers Last reply
More about burner drive read
  1. Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
    If you are trying to use XP's built-in burning function, it is not
    compatible with DVD burners. Your DVD burner should have come with its own
    software, did you install it. Also, note, there is no packet writing
    capability in XP; that's the drag and drop function or saving a file
    directly to CD as in CD-R or RW. If you have applications that work with
    the XP burning function, they might have worked with CD-Rs or RW media but
    for the most part, packet writing software must be installed for this to
    work and that would apply to either CD-R-RW or DVD burning.
    Michael Solomon MS-MVP
    Windows Shell/User
    Backup is a PC User's Best Friend
    DTS-L.Org: http://www.dts-l.org/
    "CH" <xskweegx@yahoo.com> wrote in message
    news:01cf01c4a1a5$1d77e910$a501280a@phx.gbl...
    > Hi,
    > movies.
  2. Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
    I am not using XP's burning function. My DVD drive did
    not come with any sofware thatI know about, as it came
    with my computer. I have no made a recovery disc (can't
    burn one), but I do have the drive, so maybe I could
    reinstall something off of there? My biggest problem is
    that none of my burning programs (Nero, Media Player,
    Intervideo winDVD) are recognizing the drive as a
    recording drive, only one of the image drives I have
    (Nero keeps trying to create images, not burn a CD, Media
    Player tells me I have no drives).
    >-----Original Message-----
    it is not
    packet writing
    saving a file
    Rs or RW media but
    burning.
    >Windows Shell/User
    >> Hi,
    the
    there
    hate
    >> movies.
  3. Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
    Have you always had this problem? Since the drive came with your computer,
    have you contacted the computer manufacturer's tech support about this
    issue? Have you checked to make sure the version of Nero and WinDVD are
    compatible with XP and your specific make and model DVD, you should check
    the application websites for that information.
    Windows Shell/User
    <anonymous@discussions.microsoft.com> wrote in message
    news:10f701c4a1b0$95086d50$a301280a@phx.gbl...
    > it is not
    > packet writing
    > saving a file
    > Rs or RW media but
    > burning.
    >>Windows Shell/User
    >>> Hi,
    > the
    > there
    > hate
    >>> movies.
  4. Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
    You're welcome, good luck.
    Windows Shell/User
    news:1dce01c4a1ba$d9f41ea0$a401280a@phx.gbl...
    > This is a new computer, actually. I've had it 3 weeks. I
    > have used Nero and Media player, etc on my laptop running
    > XP, so I dont know what is happening here. However, I
    > never thought to call the support line, as I am so use to
    > not having a warranty for anything I own... thank you.
    > with your computer,
    > support about this
    > Nero and WinDVD are
    > you should check
    >>Windows Shell/User
    > (can't
    > Media
    > function,
    >>> it is not
    >>> packet writing
    >>> saving a file
    > CD-
    >>> Rs or RW media but
    >>> burning.
    >>>>Windows Shell/User
    >>>>> Hi,
    >>> the
    > that
    >>> there
    > that
    >>> hate
    >>>>> movies.
  5. Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
    I guess Misery Loves Company, but its good to know you
    are not alone, or someone else is in the same boat.
    I recently built a new computer and performed a fresh
    install of windows XP Pro SP1 as the OS.
    MOTHERBOARD : MSI-KM3M-V
    BIOS VERSION : VIA KM266 Pro/KM400/ KM400A (From Box)
    Phoenix-Award Bios V6.00PG (From Display)
    W7061VMS V3.0 042004 13:20:41
    04/20/2004 KM400-8235-6A6LYM4BC-00
    CHIPSET : VIA VT8237
    CPU: ATHLON XP 1700+
    RAM: 500 Meg (w/ 32 meg shared)
    OS : Microsoft Windows XP SP1 using NTFS
    (OEM version purchased with all the other stuff)
    PRIMARY IDE CONFIGURATION:
    MASTER : HDD 80 GIG
    SLAVE : (NONE)
    SECONDARY IDE CONFIGURATION :
    MASTER : (First Try)LiteOn SOHW-1633S 16X DVD +/-R/+-RW
    Drive SOHW-1633
    MASTER : (Second Try) Optorite DD1205 12X DVD +/-RW (mfg
    July 2004).
    SLAVE : Memorex 48MAX-244816A CD R/+/-RW
    The DVD drive can be used to install WIN XP SP1, but
    after installation of OS
    The OS no longer recognizes the DVD Drive as anything
    other than an unknown
    IDE device (My Computer) In the device manage WinXP
    correctly identifies both of the
    DVD's tried but displays a yellow exclamation point.
    Checking properties I
    get: "This drive cannot start (Code 10).
    Same results obtained with both DVD writers tried.
    (Can't read, write, does not even recognise it as a CD-
    rom drive.)
    This makes it impossible to load any device drivers, or
    additional programs.
    IN Addition The Memorex unit which is a DVD player and CD
    ROM R/RW device cannot
    read CDs even though Windows XP Device Manager reports it
    a fully operational.
    The Memorex, LiteOn, and Optorite are all allegedly "WIN
    XP Compatible" according
    to their respective manufacturers. MS lists these
    devices as WIN XP compatible.
    I have checked the cables, master/slave jumpers, power
    connectors. Even swapped
    out Memory Modules, and the symptoms remain.
    HOWEVER:
    The Memorex, LiteOn, and Optorite are all correctly
    recognised and work well when
    installed on this machine with Win98SE, AND on other
    machines using Win XP SP2, Win 2000.
    My Problem is with WIN XP, but what have I done wrong, or
    what haven't I done.
    all help appreciated
    >Hi,
    there
    hate
    >movies.
  6. Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
    Check the following Knowledge Base article and see if it helps with this
    issue:
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;314060
    Windows Shell/User
    "Daemon O'DeKnight" <anonymous@discussions.microsoft.com> wrote in message
    news:258501c4a3ff$f3563e40$a301280a@phx.gbl...
    > MASTER : HDD 80 GIG
    > SLAVE : (NONE)
    > Drive SOHW-1633
    > July 2004).
    > rom drive.)
    > HOWEVER:
    >>Hi,
    > there
    > hate
    >>movies.
Drivers Device Driver Windows XP
