HD 5570 Triple monitor output
Hi all,
Has anyone actually got a 5570 to display 3 outputs simultanously ? I have a Sapphire low profile with VGA DVI & DP outputs.Using a DP - DVI converter. It will output to any 2 monitors but will not accept a 3rd to be added.
Any advice would be appreciated as I've exhausted all options I can think of (as well as my arms in shifting 5 monitors around all afternoon).
Thanks
Cuong
2 answers Last reply
More about 5570 triple monitor output
  1. jfreggie said:
    Thank you for your reply. I've just ordered a proper dp cable as my Dell 27" has a dp input. I had the converter handy and thought it would work but u live and u learn.
Radeon Monitors HD Graphics
