Will this case work with my current hardware?
KayCH
5
I'm removing the hardware from my pre-built computer, then adding it to a new and bigger case. Problem is that I don't know if my hardware will work with the case I found or if I should get another case.
The case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197&cm_re=haf_922-_-11-119-197-_-Product
My current computer:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c02925115&lang=en&cc=us&taskId=110&contentType=SupportFAQ&prodSeriesId=5080737&prodTypeId=12454
KayCH
5
Forgot to mention that I already own a Antec High Current Gamer 900W and a ZOTAC GeForce GTX 570 Synergy Edition (using both in the current case at the moment), which I plan to use in the new case, so the PSU shouldn't be a problem.
g-unit1111
Then yeah it should work. You should definitely look at upgrading the motherboard and CPU if you plan to do that.
KayCH
5
1) Is taking the hardware out of my current computer (everything possible, the Antec & the GTX 570) into the case I'm planning on buying, ensured to make the computer to work without any major problems such as overheating?
2) I'm planning on using my computer mostly to playing games, will the Motherboard or the CPU affect the performance of games?
3) Would the CPU below work? Not really on a budget, and I need to make sure everything works properly this time.
4) Any suggested Motherboard that works with my current hardware? Not familiar with any motherboards, so I have no clue when it comes to picking one.
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
jonjonjon
781
you shouldn't have any problems but there is always the risk something could happen when you move all your parts. your cpu is locked so a new mb wont make any difference. the psu wont make a difference either other then it can power a more powerful gpu. you would need to buy a cpu and motherboard.
KayCH
5
So I absolutely have to get a new MB and CPU? If so, which one is suggested for my hardware? Not really on a budget, just have to make sure everything works this time.
