Case:
Freezer Case
Power Supply:
Platinum Full Modular PSU
Motherboard:
Best Motherboard/Price
Processor:
Intel Core i5-3570K
Ram:
CORSAIR Vengeance C7
Solid State Drive:
Samsung 840 Pro 256GB
Hard Disk Drive:
Western Digital WD Blue 7200RPM/64MB Cache
Optical Drive:
ASUS 24X DVD Burner
Cpu Cooler:
Hyper 212 Evo
Operating System:
Microsoft Windows 7 Home Premium 64B
Lastly is the Video Card. I would recommend going with
MSI Lightning 7970 and picking up another one in a year when they are cheaper. If you are not an AMD guy, then
Galaxy 680. Both are good options and depending on what you're doing you could go with either one. If you plan on a 3 monitor or tv setup, the 7970 is better. But if you plan on using 1 monitor with 3d nvidia is the better way to go. For strictly gaming performance, I would give it to the 7970.
Total Price: $1,757.89 This gives you room for maybe another 7970/680 if you want to CS/SLI right now, or room for, what I would get, a nice mechanical keyboard/mouse @
Best Mechanical Keyboard Sold and a
Great Mouse but so is the G9X/500/600 series from Logitech.
And for a good review between performance, check out
http://www.hardocp.com/article/2012/07/23/msi_geforce_g...
They are using the Sapphire 7970 which is 369.99 and overclocked it pretty awesomely. Comparing it to the MSI 680 lightning. Bit of a leepfrog, as both cards are great. Price difference is considerable though.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... That's the 680.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... That's the 7970.
Hope that might help you if you're unsure on going AMD or Nvidia, GL
And as far as that ram pick for the lifetime warranty, any good company offers lifetime warranty on their ram. Here is much faster ram from a much more reliable company
Corsair Goodness. Lifetime warranties indeed.
As far as the 4GB 680 goes, I would definately get a
http://www.newegg.com/Product/Product.aspx?Item=N82E168... over that ASUS. Either card you get in this build your total is 1750. Intel SSD are slow but reliable. Go with a Samsung or Corsair SSD for speed, and reliability. You don't need to sacrifice either in today's SSD market. I put in the best SSD out right now. And lastly, the sound card, is not needed unless you actually have an amazing set of headphones, insert
http://www.amazon.com/Sennheiser-PC-350-Collapsible-Mic... here.
