Do you need to put cooling systems in a PC if you are not planning on over clocking it or will it already have enough built in fans? (I'm looking at this case): http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075. I plan on putting a i5-3750K and a GTX 660 in it?
Also Can someone point me in the general direction of something to help me assembly my PC? I assume the different components come with basic instructions but is putting everything together extremely confusing?
Thanks
Thanks
