Approximate Purchase Date: most probably today
Budget Range: 2000-3000 dollars (budget is not a problem so i would not mind going for the absolute best)
System Usage from Most to Least Important: Gaming, Photoshop, Internet, Movies, Music, Minecraft Server
Are you buying a monitor: Yes, but its not included in this build, i also own a 1080p monitor will be using it as my 2nd monitor but not for games
Parts to Upgrade: Everything
Do you need to buy OS: No, i have a Copy of Windows 7 Ultimate from work
Preferred Website(s) for Parts: Amazon only
Parts Preferences: Strictly Asus, nVidia, Corsair, Intel, EVGA
Overclocking: Maybe, when i need to
SLI or Crossfire: Maybe
Your Monitor Resolution: 2x1080p might add a 3rd (only one will be used for gaming)
Additional Comments: i have assembled 2 builds which i really like, i am not sure which one will be better because i don't like to upgrade/change my PC very often so will be keeping this for quite sometime
-Aw and also please don't recommend similar products that are cheaper from other brands
Why Are You Upgrading: Currently using my 4 year old iMac Core 2 Due with both Windows 7 and Mac OSX installed
http://pcpartpicker.com/p/tTAk
http://pcpartpicker.com/p/tTHe
