Compatibility of home built system
Hi
It's been a while since I last built a system, around when the 1st Gen of Core Duo came out :D
I would just like to ask if these components will work together.
Motherboard
Gigabyte GA-Z77M-D3H Motherboard, Socket 1155
CPU
Intel Core i5-3550 3.3GHz (3rd Gen)
RAM
Corsair 2x4GB RAM Vengeance DDR3 1600MHz DIMM 240-pin
Many thanks and Merry Christmas
4 answers Last reply
More about compatibility home built system
  1. Also for those wondering what the rest of the specs are
    PSU
    Corsair GS600
    GPU
    Radeon 6570 HD 1Gb
    CASE
    Corsair Carbide 200r
  2. very great build :D yes it will work perfectly
    it needs improvement on PSU and GPU
    you may want to swap GS series to any CX or TX series from corsair. those have higher build quality. eventough for lower wattage 430-550
    and get at least 6670, 6770 or 7750 :) they have DDR5 which will be much better performance for similar price
  3. Thanks.
    Unfortunately I already own the GPU and PSU and can't really afford new ones atm what with just buying this.
    Will the GS600 be ok for now? I can always upgrade it next month when I get paid again!
  4. as i said, it will work perfectly
    changing psu and gpu is has no advantage, negligible. you may want to spend later on 120GB SSD for a better working experience
Homebuilt Core Compatibility Systems Product
