hey! i'm planning on building a gaming computer, i have a ~1000$ budget, this is my FIRST build so i'd like to know if everything i shopped are compatible before i buy them, and if you have some recommendation about replacement let me know!
processor : http://www.newegg.ca/Product/Product.aspx?Item=N82E16819113284
motherboard : http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157319&Tpk=ASRock%20970%20PRO3%20AM3
case : http://www.newegg.ca/Product/Product.aspx?Item=N82E16811139008
power supply : http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139040
hard drive : http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136769
Cd drive / burner : http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
video card : http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125418
memory : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145345 ( X 2 )
Windows 7 : http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116986
i just want to make sure everything is compatible and will work fine together, also let me know if it will make a good ~1000$ gaming machine, thanks!
