I just need some advice on my first PC build. I put this together using the format in the upgrade and build advice sticky. I hope it's easy to read and makes sense. Thanks in advance for any help you can provide me!
Approximate Purchase Date: ASAP, whenever I get a build I'm comfortable with purchasing I'll be making the purchase.
Budget Range: $1200 max(including shipping, not including the rebates)
System Usage from Most to Least Important: Gaming, Gaming, Movies, Surfing the net
Are you buying a monitor: No
Do you need to buy OS: Already bought a new copy of Windows 7
Preferred Website(s) for Parts: Newegg or Amazon
Parts Preferences: Intel CPU, Nvidia video card
Overclocking: Not really interested in OCing
SLI or Crossfire: Not right now(maybe in the future)
Your Monitor Resolution: 1920x1080
Additional Comments: I'll be playing games likes like Dishonored, Batman: Arkham Asylum(and City), Skyrim.
Why Are You Upgrading: I'm currently using a 4 year old PC my father bought for me and it has been reliable but its age is starting to show. Instead of upgrading small parts here and there(in this dell xps), I want to just start new.
The following are the parts I've put together so far:
CPU: Intel Core i5-3450 Ivy Bridge 3.1GHz (3.5GHz Turbo) LGA 1155 77W Quad-Core $194.99
Mobo: ASRock Z75 Pro3 LGA 1155 Intel $84.99
Video Card: GIGABYTE GV-N670OC-2GD GeForce GTX 670 2GB $399.99
Hard drive: WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA III, 64 MB Cache - WD10EZEX $77.99
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) $44.99
Case: COOLER MASTER HAF 922 RC-922M-KKN3-GP $99.99
PSU: Rosewill Green Series RG530-S12 530W $54.99
CPU Cooler(I was told by a friend I should pick one up): COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 $29.99
