HELP! Is a 600w PSU enough for this HD 6870 and specs?
Hello!
So I am upgrading my computer's graphics card and I was wondering if with my specs and 600w PSU would be able to run it with no problemos.
My specs:
CPU: AMD FX-6100 @ 3.3GHz - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU: Sapphire 6870 1GB (this is what I'm gonna be upgrading to) - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
RAM - 10GB DDR3
Motherboard: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03...
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168... 600w
For other specs the computer can be found here (some parts have been updated as stated above) http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en...
If anyone could help that would be very helpful! Thanks!
More about : 600w psu 6870 specs
Graphics card Expert
Deltastorm said:
Hello!
My specs:
RAM - 10GB DDR3
yup it will be enough.. :)  corsair are at best in making PSU's but i want to give you a little advice..if you are not planning to upgrade your system or PSU in upcoming years..then do take a look on this...its very popular psu for gaming and better then CX series....20 $ more but worth it as SINGLE TIME INVESTMENT......
Ask the community
