Closed Solved
Power Supply and Graphics Card Upgrade
i have a hp pavilion elite hpe 510t with intel core i7. it has a 300watt power supply and nvidia geforce 405 graphics card.what i want to do is upgrade both power supply and graphics card.what would you recommend for both.
7 answers Last reply Best Answer
More about power supply graphics card upgrade
  1. What is your budget?
  2. no need to upgrade your power supply if you get the 7750.
    its a fairly powerful card that consumes very little power.
    it has same performance as 5770 and it would run fine on your 300 watt psu
  3. I have to ask for your budget as well. HD 7750 will work but it's a pretty weak card.
  4. u also need to specify the model of the power supply. The watt rating is not enough info
  5. Best answer
    weak as in ? dont forget that he's upgrading from integreted graphics so the performance difference between the two will blow him away .
    though he hasnt specified his monitor res as well
  6. Weak as in will not let him play games on high settings. For a PC with an i7 to be balanced, it would have to be at least GTX 660.
  7. Best answer selected by rocheretired64.
Graphics Cards Power Supplies Graphics
