So I'm buying a PC on CyberPowerPC and I HAVE to choose a graphics card. I was thinking of choosing a low end (like a 630) graphics card and then buying the Gigabyte 7950 on NewEgg. Would I be able to set the 630 as a dedicated PhysX card and then use my 7950 for all the game rendering? Or do I have to use SLI/Crossfire and graphics cards from the same series? Or can I just use the two separate cards how I explained above?
Thanks!
Thanks!
