Hi all,
I was hoping some of you experts could help me out with this. I have the following config:
Mobo: Asus M5A78L Series
CPU: AMD FX-6100
RAM: 2x4 GB Kingston 1333 Mhz
GPU: MSI Nvidia GTX 670
HDD: Samsung 80GB
PSU: OCZ 650W
Today, my computer would not start. When I pressed the power button. On opening the case, here's what I observed.
If I pressed the power button, the CPU/Case fans/lights would start for just a second and then stop. No POST/Power, nothing.
So I took the components out and tested as follows:
PSU: I tested using a digital PSU tester and found that all voltages were within the normal parameters. So the PSU is fine.
CPU, single stick of RAM, and HDD - POST successful.
CPU, both sticks of RAM, and HDD and Optical Drive - POST successful
CPU, both sticks of RAM, HDD, ODD, and Graphics card - Power for a second and no POST.
Here's the interesting bit. The Nvidia GTX 670 has 2 x 6-pin slots for power. When I do not connect any power, the system completes POST but obviously the card is not detected. If I connect just one of them (the left one), the system posts. But if I connect both, the system does not post.
I tested both the 6-pin connectors from my PSU and they are fine. Could there be an issue with my GPU? Secondly, why would it post with one power connector, and not let the system power on for more than a second when the second one is connected?
Any ideas? If you're certain my card is fried, are there any repair options? It's just 3 months old and I really don;t want to spend £ 300 on a new card right now
Best Regards,
Sol
CPU: AMD FX-6100
HDD: Samsung 80GB
PSU: OCZ 650W
Best Regards,
Sol
