Boot problem
Dear Tom's
I have recently built a computer with the components below. I installed all the parts and turned it on for the first time and after roughly 5 seconds the computer turned off by itself and then would turn back on again and would continue to do this. I tested with only the bare minimum components (MoBO, Ram,Cpu,powersupply and it will still continue to do this? could anyone tell me what the problem is ... (also When it turned off I am not 100% sure on this but i think i heard one beep about 1 second before it turned off.) I have already tried a different powersupply and it was still the same problem. Does anyone know what the problem is and how I can fix it?? :cry: :cry: :cry: :cry: :cry: :cry:
Cpu: is-3570k
Ram: G-Skill ares 1600 mhz 2 x 8gb
Mobo: Asrock B75-pro 3-m
Powersupply antec 550 w power supply
Gpu: 7870
Thanks for any help
2 answers Last reply
More about boot problem
  1. this one is really long troubleshooting but it can save you from getting headache
    http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems
  2. Thanks found problem one screw tied into the mobo was on crooked shorting the board
Homebuilt Systems
