ETA the template:
Approximate Purchase Date: This Saturday
Budget Range: $800 - $900
System Usage from Most to Least Important: Games/Writing/Streaming/Movies
Are you buying a monitor: Yes
Do you need to buy OS: Yes. (Will be buying an upgrade version of Windows 8)
Preferred Website(s) for Parts: www.danawa.com (it's in korean, blech)
Location: South Korea - will be traveling to Seoul to make the purchases at the computer market.
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 2560 x 1440
And Most Importantly, Why Are You Upgrading: Because I need a system I can effectively work on (currently using a notebook - I find it hard to work on it) and play on.
Hi guys.
I'm putting together a gaming PC, expected purchase date being this Saturday. I'm having trouble settling on which motherboard to buy - primarily because:
a) I want to be able to use Intel's Smart Response Technology; and,
b) I want the best value for money I can get.
Current options are, from starting with the cheapest:
1. ASRock z68 Pro3 Gen3 ($95ish)
2. ASRock z77M
3. ASRock z68 Extreme3 Gen3
4. ASRock Z77 Pro 3 (I'd go for this if I were sure it supports ISRT but the ASRock page is silent)
5. ASRock Z77 Pro4-M ($117ish)
I'm not particularly attached to ASRock but I'm in Korea and it seems to be cheaper here - I only see H61 and H67 boards from Asus and MSI in the same price range.
The other components of my build are:
CPU: Ivy Bridge Core i5 3570k
GPU: HD6870 1GB OR GTX 650ti 1 GB (Please comment on which you'd suggest for this too. In the unlikely event that I can afford it, I'd go for the 7850. Failing that, these two are the options)
SSD: Crucial M4 mSATA 32 gb
HDD: Samsung h5002HJ 500gb
RAM: 2x4gb @ 1600 (Some Korean manufacturer)
PSU: 600W (Some Korean manufacturer)
LCD: A giant Korean 27" 2560 x 1440 LED
(All of which will set me back around $800 - 900. Comments/suggestions on the build are welcome.)
Also, no, I am unlikely to try SLI/Crossfire in the future. I am more likely to try OC on the CPU/GPU.
Thanks in advance!
Overclocking: Maybe
Hi guys.
2. ASRock z77M
Thanks in advance!
