Parts compatible
hey, can anyone tell me if these parts are compatible, I checked on pcpartpicker and it says a minor issue is Gigabyte GA-Z77-D3H ATX LGA1155 Motherboard has an onboard USB 3.0 header, but the Cooler Master Elite 430 ATX Mid Tower Case does not have front panel USB 3.0 ports.
Intel Core i5-3570K 3.4GHz Quad-Core Processor
Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Sapphire Radeon HD 7850 2GB Video Card
XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply
Lite-On iHAS124-04 DVD/CD Writer
can anyone suggest an alternative case if this one is not compatible
any help appreciated
5 answers Last reply
More about parts compatible
  1. go for corsair 400 r case its a plenty of room for accessories can intall easily and + front two 3.0 usb slot too
  2. Agree'd with monu, the 400r is a great case with great airflow. Very easy to build with and plenty of space for many components!
    Moley
  3. is this it
    Corsair Carbide 400R Midi Tower Case
    the depth unfortunately is a bit too much by like 15 cm is there any other alternative anyone can suggest if not I will just get that most likely
  4. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
  5. what does this mean just out of curiosity I f i dd get my original case would i not be able to use usb things.
    also I was looking online at some cases and came across the Antec 900 Nine Hundred Ultimate case but from the images I could not see anywhere to insert disks, is this correct?
New Build Compatibility ATX Systems
