I did my homework and research but nothing beats experience (which I lack terribly) from those used to and have knowledge on rigs/builds.
Needed a PC for:
- Programming
- A little image and video editing
- Playing PC games; Strategy (dota2, SC2), FPS (CoD, BF3...), Diablo3 **note: i can live with average settings
- Running PSX/PS2 emulators on maximum settings
- Multi tasking between games and browsing the Internet, emails and stuff.
- Can handle Rainmeter and other software/apps that customizes.
This is what I've come up with:
http://pcpartpicker.com/p/ur0t
Notes:
- Budget of $900 - $1000
- I do not plan to Overclock
- I want to see this build live long
- Not sure if PSU wattage is adequate for the build
- Not sure if CPU choice is good
- Might add a monitor or two in the future
All suggestions, criticisms and comments are welcome. If possible, state why, why not where appropriate. Thanks very much!
[I'm writing this down on ask community widget thingy(?). Will it transfer to a thread later.]
Needed a PC for:
- Programming
Notes:
