I helped a friend with a PC build and the PC will not boot. When the power is pressed, it does turn on but nothing shows up on the monitor.
So far,
1. I checked the cables twice.
2. Checked the ram with memtest with no problems.
3. Tried booting with working ram from my PC.
4. Tried booting with ram in different slots and a single stick at a time.
4. Tested the gpu with my PC. Works Perfectly.
5. Used my power supply from my PC to power his. Turns on but nothing is shown on monitor.
6. Checked the cables twice again.
7. Unplugged HD and DVD drive since I only want to see the motherboard bios. No success.
8. Plugged my motherboard speaker into the new motherboard. No success.
9. Flipped the speaker in the motherboard. Still no success.
The only parts I haven't tested are the Hard Drive, DVD Drive, CPU, and Motherboard. But even with unplugging the Hard Drive and DVD Drive, the bios wont show. I believe there is a problem with the motherboard since there was no sound from the speaker and there was a crackly noise when I inserted ram in 2/4 of the slots.Are there any other thoughts? This is my second build and I can't seem to get it to work. I also followed the steps fromhttp://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems . I give my thanks in advance.
Build:
ASRock 970 Extreme3 AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
AMD FX-6100 Zambezi 3.3Ghz AM3+
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
PNY XLR8 8GB 1600 DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820178382&Tpk=PNY%20XLR8%208GB%201600%20DDR3
Seagate Barracuda 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
LG 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
Thermatlake 700Watt PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153167&Tpk=Thermaltake%20700w
MSI GTX 460 Twin Frozer II
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127519
NZXT Source Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146076
Windows 8
So far,
Build:
LG 24X DVD Burner
NZXT Source Case
Windows 8
