New build Purchasing parts tomorrow
OK so I am ordering parts tomorrow, I want to know if these parts will go good together? My budget is around 1k
I'm dead set on the case, and an nvidia gpu
I will be purchasing all the parts from newegg.
http://pcpartpicker.com/p/uw0s
Any changes anyone would make? Any advice?
PC will be for gaming, adding a 1tb 7200rpm drive later on for fraps recording and backup storage
16 answers Last reply
More about build purchasing parts tomorrow
  1. im also dead set that a fractal case would be much better than a inwin case, given my experience with a core 3000, a define R3 and R4 case. plus, its cheaper as well
    normally id recommend a 7870 but then a 660 is cheaper right now
    id suggest a mechanical keyboard over a membrane anyday. they are built better, they last way longer (50 million keystrokes vs 2 million), and are generally more comfortable to type on. made me type faster as well but that is different for anyone
    http://pcpartpicker.com/p/uwjY
    id suggest buying from either us.ncix or newegg. us.ncix has price matching and free shipping. only the ram has to be bought at amazon. newegg sells it for 12 bucks more which is a scam almost
  2. ok lets make it quick before you purchase :
    - downgrade to a i5 3470 and you will not lose a single fps in any game.
    - change the SSD to samsung 830 or hyper X 3k or OCZ vertex 3.
    - IF you want just pay more $10 and get this fully modular psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
    rest of the build is very good
  3. you will probably lose 1fps in a worst case scenario, just saying
  4. I wanted a samsung 830 256gb, but it was sold out on newegg, I am purchasing all the parts from newegg only, so can anyone recommend a reliable SSD for 200?
    Also the ram I chose is because it has been tested & works with the motherboard I chose
  5. why only newegg? you waste money that way. it costs 150 more dollars by just getting it at newegg
    all ram from good brands work the same on all boards. for intel boards, as long as its 1.5v and 1600mhz or lower, it just works. no difference
  6. I guess just a personal preference, I'm ordering all parts at once, So I'm gonna go with newegg, Is the sandisk 240gb SSD you listed in above build reliable? I want one that will last for awhile.
  7. yes its good. but then you will have to pay 150 dollars for a "personal preference."
  8. Ok, I went with a samsung 840 pro 256gb, it has a 30 dollar off promo right now, Build over all is more expensive, But its my first so I'm bound to make mistakes :3
  9. why would you want to make mistakes in the first build? id rather do it right the first time and forget about it later on
    there is literally no difference between a 840 pro and a sandisk extreme in daily operations. only in benchmarks
  10. I'm with TheBigTroll: I love Newegg, but the rig I just built had nothing from them. I got a i5 3570K for $179 from Tigerdirect.ca. I used Tigerdirect, and NCIX this time. Last time was all Newegg.
    As far as the build? All good. Glad to see you went with a good power supply.
    If I were you, I'd get an overclockable CPU such as I5-3570K and decent Z77 mobo over locked cpu, h77 mobo, and an ssd.
    Having an ssd is great but within given amount of budget, I'd invest in more on CPU, mobo, GPU, and PSU for better gaming experience.
    SSD does load games faster but it does not increase in game fps while you are actually playing but having better cpu, mobo, and gpu will make noticable amount of differences.
    I'd go with higher wattages PSU over that 550w gold certified just incase for future crossfire/SLI option down the road.
    Memorywise, Samsung makes one of the best performing ddr3 memory sticks at a really affordable cost and is very highly overclockable.
    Other peripherals, such as mouse, keyboard, and speakers are really subjective but I'd like to recommened Logitech g500 for a mouse, and mechanical keyboards over basic membranes.
    I made a wish list for ya so just leave me your email address and i will send in over to you
    Good luck building and have fun
  12. don't listen to him get an ssd. you don't need a bigger psu because i highly doubt you will be using sli with a micro atx board. i would get this. it has a better cpu, mb, gpu and one could argue a better ssd because it uses toggle nand. i don't have any experience with micro cases so im not going to even suggest one. also don't spend $50 on a non mechanical keyboard.
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($219.99 @ Newegg)
    Motherboard: Asus P8Z77-M Micro ATX LGA1155 Motherboard ($112.50 @ Newegg)
    Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($35.99 @ Newegg)
    Storage: Sandisk Extreme 240GB 2.5" Solid State Disk ($159.99 @ Newegg)
    Video Card: MSI GeForce GTX 660 Ti 2GB Video Card ($239.00 @ Newegg)
    Case: Inwin Dragon Slayer MicroATX Mini Tower Case ($89.98 @ Newegg)
    Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($59.99 @ Newegg)
    Keyboard: Microsoft SIDEWINDER X4 Wired Gaming Keyboard ($49.99 @ Newegg)
    Mouse: Logitech G9x Wired Laser Mouse ($79.99 @ Newegg)
    Total: $1047.42
    (Generated by PCPartPicker 2012-12-27 23:57 EST-0500)
  13. I upgraded your PC a LOT.
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
    Motherboard: Intel BOXDZ77SL50K ATX LGA1155 Motherboard ($107.55 @ Newegg)
    Storage: Samsung 840 Series 250GB 2.5" Solid State Disk ($180.00 @ Adorama)
    Video Card: EVGA GeForce GTX 660 Ti 2GB Video Card ($229.99 @ Newegg)
    Case: Antec Three Hundred Illusion ATX Mid Tower Case ($59.99 @ Newegg)
    Power Supply: SeaSonic 650W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($89.99 @ Newegg)
    Keyboard: Microsoft SIDEWINDER X4 Wired Gaming Keyboard ($40.99 @ Newegg)
    Mouse: Logitech G9x Wired Laser Mouse ($64.99 @ Amazon)
    Total: $1019.48
    (Generated by PCPartPicker 2012-12-28 02:41 EST-0500)
    I'll list the changes.
    Faster, overclockable CPU
    Higher quality motherboard which allows overclocking
    Better RAM kit.It's the same speed and latency but works at a lower voltage, making it a lot better.
    Faster SSD.
    Faster Graphics card.
    Better case.
    Better power supply.
    All in all it's a huge improvement.
  14. Already ordered the parts, I wanted a micro atx desktop, Thanks for the help though! And I believe the non pro versions of the 840's are TLC, not as reliable as the MLC I ordered, 128gb is plenty for me, never used a SSD so I wouldnt notice the speed difference, all in all, I'm happy with what I ordered :P
New Build New Build Systems Product
