Tom's Hardware > Forum > Windows XP > Device Driver > linking problem in driver
Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
Hi ,
I am trying to build a FS filter driver wherein i have a .cpp file and some
..c files. I want to use a function from .cpp file in a .c file.
The .cpp file has the desired function declaration in extern "C" { ...}
: extern "C" int abc();
: int abc(){ ... }
and the .c file has the plain function declaration and uses the function
: int abc();
: void xyz(){ abc(); }
while linking these files together i get "LNK2019 :unresolved external
symbol _abc@0 referenced in function _xyz@0 "
When i looked into .obj files for these .cpp and .c files and found "_abc@0"
in both. I think that is what it should be and still i cannot
identify the problem.
The sources file i used looks something like(I have cut the irrelevant
matter) :
TARGETNAME=xyz
TARGETPATH=obj
TARGETTYPE=DRIVER
BASEDIR=..
DRIVERTYPE=FS
USE_MAPSYM=1
USE_NATIVE_EH=1
USER_C_FLAGS=/Tpa.cpp #a.cpp file contains the function to be used
C_DEFINES= /I$(BASEDIR)\include
SOURCES=b.c #b.c file uses the function from a.cpp
Anyone who has encountered similar problem plz help.
Thanx
Sushant
Sponsored Links
There are 935 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
