"If there are a cheapest/better option to one of my pieces let me know!"
That's what he said i just made a good list for him for less price that he had, also Kamen_BG is crappy one, a crap mobo, a crap sdd, a overpriced card and more expensive total than he had, the good thing is the psu...
That's why i'm getting tired of suggesting hardware, then to be bashed by others.
He had a nvidia card in the list, what people do? recommend AMD cards, saying the same bullshit story they overclock rather well than nvidia, they surpass all nvidia cards blah blah. etc, also put charts that favors amd, forgetting that nvidia beats in most games amd cards, see the e.g. i gave that was the recent games, all actually in present tense.
That link was to show that not everything is raw fps, the 660ti has more percentile fps, techreport showed it and well without bias(see the several test).
Also nvidia has way better mature drivers, exclusive features, more smoothness, more stability.
Did you occur that he might rather prefers nvidia cards, and the card that i recommended is the natural upgrade from the one he had(he put a 660ti pe ,i suggested the 670 gtx pe)?
And you're incorrect, the 670 gtx is on the level with the 7970, there's no 7950 that can reach a stock 670 gtx(we're excluding overclocks cause that's always subjective, i've seen 7950 with voltage locked and it all depends on the binned chips).
And don't even make me discuss the things like SLI vs crossfire, cause nvidia is way better also for multi gpus setups, more smoothness, better scaling, and driver support.
There's also this :
http://pcpartpicker.com/ca/p/uDSv or the msi pe 670 gtx:
http://pcpartpicker.com/ca/p/uDQn
For SSD :
http://pcpartpicker.com/ca/part/sandisk-internal-hard-drive-sdssdx120gg25 or
http://pcpartpicker.com/ca/part/crucial-internal-hard-drive-ct256m4ssd2
That's all, i'm not having more discussions on this thread, if you want to bash, go ahead.
