Hi I have a BT Home Hub 2.0A that I want to unlock touse on my cable Virgin Media broadband.
So I followed an unlocking process for the BT HH 2.0A and the instructions on how to get the ETH4 working (im totally a newbie to this)
Now heres where Im going wrong!
Im doing the telnet and loggin into the routher and see the cracked login part.
However when im entering the commands on that page e.g
pp relay flush
pp flush
:eth flush
:atm flush
:atm phonebook flush
:eth bridge ifdelete intf=ethport4
:eth ifadd intf=eth_wan
:eth ifconfig intf=eth_wan dest=ethif4
:eth ifattach intf=eth_wan
:ip ifadd intf=ip_wan_eth dest=eth_wan
:ip ifconfig intf=ip_wan_eth status=up
:ip ifattach intf=ip_wan_eth
:nat ifconfig intf=ip_wan_eth translation=enabled
:dhcp client ifadd intf=ip_wan_eth
:dhcp client ifconfig intf=ip_wan_eth metric=5 dnsmetric=5
:dhcp client rqoptions add intf=ip_wan_eth option=dhcp-lease-time
:dhcp client rqoptions add intf=ip_wan_eth option=dhcp-renewal-time
:dhcp client rqoptions add intf=ip_wan_eth option=dhcp-rebinding-time
:dhcp client rqoptions add intf=ip_wan_eth option=subnet-mask
:dhcp client rqoptions add intf=ip_wan_eth option=classless-static-routes
:dhcp client rqoptions add intf=ip_wan_eth option=default-routers
:dhcp client rqoptions add intf=ip_wan_eth option=classfull-static-routes
:dhcp client rqoptions add intf=ip_wan_eth option=domain-name-servers
:dhcp client ifattach intf=ip_wan_eth
I get stuck on:
Now... If i have my laptop connected to the hub on 1,2 or 3 of the ethernet ports when i run this one command I get the error:
Invalid interfact name
Bad value for parameter 'intf'
Unknown Command.
[attachment=0]ololol.png[/attachment]
But all the other commands run fine, i tried plugging the ethernet from my cable modem into ETH4 and connecting (wireless and hardwire) but still had no internet connection.
So then i tried running the list when connected to the Hub on ETH4, when i ran the :eth bridge ifdelete intf=ethport4
Command it simply booted me fromt he router (im guessing this disables ETH4 or something?)
Ok so THEN i thought maybe if i run the commands plugged into ETH4 and then when it boots me plug into ETH1 i can carry on wiht the commands, which I did but when i tested the internet again it did not work!
Im stuck and i would really appreciate any help!
Thank you for the great tutorials
Ash
pp relay flush
pp flush
:eth flush
:atm flush
I get stuck on:
Unknown Command.
Ash
