Approximate Purchase Date: e.g.: this month
Budget Range: 600-700 dollars.
System Usage:gaming
Are you buying a monitor: no(already hav one)
Do you need to buy OS: No
Preferred Website(s) for Parts: anywere.
Parts Preferences: AMD
Overclocking: maybe(most likley yes)
SLI or Crossfire: No
Your Monitor Resolution: 1080p (1920 × 1080)
DO NOT NEED:keyboard,mouse,monitor, or operating system.
Parts that i have put together already on newegg:
CPU: AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
CASE:Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
HDD:Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
optical drive:LG 24X DVD Burner.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136259
RAM:Mushkin 997008 DDR3 UDIMM (2x4GB) 8GB PC3-14900 1866MHZ 9-10-9-27 Redline Ridgeback 1.5V
http://www.amazon.com/Mushkin-997008-PC3-14900-9-10-9-27-Ridgeback/dp/B0052WLU4Q/ref=sr_1_2?ie=UTF8&qid=1356671960&sr=8-2&keywords=Mushkin+Redline+8GB+%282+x+4GB%29+DDR3-1866+Memory
MObO:ASUS M5A78L-M LX PLUS AM3+ AMD 760G Micro ATX AMD Motherboard
http://www.amazon.com/M5A78L-M-LX-PLUS-Micro-Motherboard/dp/B005WUUFBW/ref=sr_1_3?s=electronics&ie=UTF8&qid=1356672151&sr=1-3&keywords=am3%2B+motherboard
PSU:NZXT Hale82N 650W 80 Plus Bronze Active 240-Pin Non-modular Power Supply, Black np-1bn-0650a-us
http://www.amazon.com/Hale82N-Bronze-240-Pin-Non-modular-np-1bn-0650a-us/dp/B008RK9VFU/ref=sr_1_4?s=electronics&ie=UTF8&qid=1356672224&sr=1-4&keywords=NZXT+HALE82+650W+80+PLUS+Bronze+Certified+ATX12V+%2F+EPS12V+Power+Supply
and i would like to know what GPU you guys would suggest to me with this setup and i would like to know if there are any better/cheaper parts that i can use.
thanks.
System Usage:gaming
thanks.
