Sign-in / Sign-up
New Build Upgrade Help
  • New Build
  • Systems
  • Product
Last response: in Systems
December 29, 2012 12:28:15 AM
Hi guys,
I originally intended on just replacing my SLI 9800GTX+ cards with a more modern video card for use with Guildwars2 and anything else on the horizon. I was informed that my core 2 duo was really the problem, which unfortunately means an almost complete rebuild. I don't really want to spend a lot of cash, but I would like a sizable upgrade if that's possible. Here's what I currently have:
C2D E8500
4GB Kingston RAM
Gigabyte LGA 775 MB
2x EVGA 9800GTX+ in SLI
650W Corsair PSU
Antec 300 case
Here's my idea for a replacement:
MB (ASRock H77) - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU (i5-3350P) - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
RAM (corsair 8gb 1600) - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GFX (evga 660ti 2gb) - http://www.amazon.com/EVGA-GeForce-2048MB-Graphics-02G-...
Does this seem like a good upgrade? Worth the money? Anything else I may need? I do not plan on overclocking.
Also, I'm running Windows 8, which I purchased as an upgrade (for my Windows 7 upgrade). In previous builds, I had to re-install Windows. Is there any way around this now adays?
Thanks!
More about : build upgrade
December 29, 2012 1:00:03 AM
Figured I'd fill this out.
Approximate Purchase Date: this week (the closer the better)
Budget Range: 300-400
System Usage from Most to Least Important: (gaming, surfing the internet)
Are you buying a monitor: No
Parts to Upgrade: CPU, mobo, RAM, Video
Current PSU: Corsair HX650
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg, amazon
Parts Preferences: by brand or type: Intel, Nvidia
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
And Most Importantly, Why Are You Upgrading: Game lagging when lots going on, on minimal gfx settings
m
l
December 29, 2012 1:28:39 AM
I like every thing but you could get a better cpu for $10 more
Microcenter i5 3570k
I know you only want to use amazon or newegg. but this is a cool place too..top of the line i5 on the cheap. I never ordered of line but i go to the store here in Baltimore they just opened up (its the greatest thing ever lol)
I got a 2700k for $220 sandy bridge the ivey bride version 3770k is at $230 way cheap
if you go with i5 3570k you can overclock but not with the mobo you have selected you would need to go with asrock extreme4 but is out of budget .
I would still go with what I posted even thought you dont need an unlocked cpu its still better then what you have for just $10 more
m
l
December 29, 2012 1:36:55 AM
I actually drive past that Microcenter in Fairfax three times a week, and have been shopping there since the 90s. Didn't realize they had gotten competitive. Wonder if they have the 3570 in stock. Is the GA-Z77-DS3H motherboard a good board?
Only problem is taxes, I suppose, but Newegg charges for shipping, and Amazon Prime sells for a higher base.
m
l
Anonymous
December 29, 2012 6:01:57 AM
just pick up a i5-3470 from there for $149.99 and get the other parts for your build:
it look good. well now if you can squeeze a GTX 670 in there . . . :ange:
m
l
