Solved
No signal input, new build
Last response: in Systems
December 29, 2012 5:48:34 AM
Hello this is my first time building a pc from the ground up. I have before changed out parts and done minor repairs and I figured now would be a good time to try a build of my own. I got the parts already, assembled the pc per whatever instructions I could find, and powered it on. While it powered on, the led's lit up, fans turned on, the monitor still read no signal.
I made sure the monitor was on the correct input and all the internal connections are in line but no luck.
Case: Corsair Graphite Series 600T
Graphics: SAPPHIRE Vapor-X 11163-05 Radeon HD 5770 1GB 128-bit GDDR5
Motherboard: SABERTOOTH 990FX R2.0 AMD 990FX(AM3+)
Monitor:ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor
Power Supply:CORSAIR TX Series CMPSU-750TX 750W
SSD: hOCZ Vertex 2 OCZSSD3-2VTX90G 90gb internal
HD: Seagate Barracuda ST1000DM003 1TB intenral
Wifi: Rosewill RNX-N300X IEEE 802.11b/g, IEEE 802.11n Draft 2.0 PCI Wireless Adapter
Blue-Ray: ASUS Black 12X BD-R 2X BD-RE 16X
Processor: AMD FX-4170 Zambezi 4.2GHz (4.3GHz Turbo) Socket AM3+ 125W Quad-Core Desktop Processor
RAM: four G.SKILL Ripjaws Series 240 pin DDR3
Fans:XIGMATEK FCB (Fluid Circulative Bearing) Cooling System Crystal Series CLF-F1252 120mm Red LED Case Fan
I am really running out of ideas on what to do with this, I cannot see anything on my screen, and since neither the motherboard nor case have a built in speaker for bios I can't tell if the bios is running into a problem.
If someone could please help me I would really appriciate it.
More about : signal input build
Best solution
December 29, 2012 5:57:12 AM
Tell me this. Is there any LED's that light up on the board to indicated a area of possible problem?
December 29, 2012 6:29:58 AM
The SB_Power LED and Dram LED
December 29, 2012 6:40:53 AM
Correction the DRAM_LED is flashing
December 29, 2012 6:25:20 PM
Ok try removing one stick at at a time of RAM.
December 29, 2012 9:50:42 PM
When I was down to two it decided to run, thank you.
December 30, 2012 2:04:55 AM
The motherboard nor the O.S. Will detect more than 4 gigabytes of memory now while I currently have 12 gb worth of ram installed.
December 30, 2012 3:39:43 AM
What bit of Windows 7 did you get? Windows 32bit won't detect anything over 4 GB
December 30, 2012 3:41:15 AM
I have 64 bit.
December 30, 2012 3:50:11 AM
Ok well did you try either of the sticks that you took out?
December 30, 2012 3:51:27 AM
Ya, I currently have all four in and it still says I have 4 gigs, three sticks says four gigs, so on and so forth.
December 30, 2012 4:02:15 AM
Ok well either you have a dead DIMM which would probably raise a major flag and you probably wouldn't even post if that was happening. SO I'm still thinking its a dead stick
December 30, 2012 4:03:46 AM
That would be three dead sticks at this point f it were true.
December 30, 2012 7:23:13 AM
I moved them around after having made sure they were all in and now they all read.
December 30, 2012 4:59:41 PM
so it works now for you?
December 31, 2012 4:53:18 AM
Everything works, thank you for the help.
December 31, 2012 3:17:14 PM
No problem. Please Select a best Answer before you go. And remember if you need anymore help were always here to help
January 2, 2013 8:42:33 PM
Best answer selected by Devimon.
