OS and optical drives already purchased, excluded from $500
Approximate Purchase Date: January
Budget Range: $500
System Usage from Most to Least Important: It will only be used to mix and master music. Programs Sound Forge & Sonar
Preferred Website(s) for Parts: Amazon/Newegg/Tiger Direct
Country: United States
Parts Preferences: whatever you thinks reliable
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: Dual HD 20" Monitors
Additional Comments:
I have 3 concerns at the moment:
-if the power supply will support everything
-if everything's compatible (like memory)
-and can the on board video card support two HD monitors or do I need to purchase one? This machine wont be used for gaming but dual monitors help with multiple programs while mastering songs.
Here's what I have so far:
CPU:
Intel Core i5-2310 Sandy Bridge 2.9GHz (3.2GHz Turbo Boost) LGA 1155 95W Quad-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115089
Motherboard:
ASRock H77M LGA 1155 Intel H77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
Memory:
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
SSD:
Kingston HyperX 3K SH103S3/120G 2.5" 120GB SATA III MLC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
Power Supply:
COOLER MASTER eXtreme Power Plus RS-550-PCAR-E3 550W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171038
Case:
COUGAR Volant Black Steel ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811553006
Help appreciated!
Budget Range: $500
Overclocking: No
CPU:
Motherboard:
Memory:
SSD:
Power Supply:
Case:
Help appreciated!
