ASRock Z77 New Build, Fans power on with power supply, no boot
strider87
So I just put together by new computer yesterday,
ASRock Z77 Extreme4
i7 3770K
Patriot 16GB
Gigabyte GTX 670
Corsair TX850M
Corsair 600T (case)
Corsair H80 cpu cooler
The first time I tried to power on I saw the system boot to life for a split second, seemed like the case fan lit up.
After that nothing happens when I try to power on, fans are constantly running even when I just start the power supply. Often time both cpu fans will come on then one or both will stop while the case fans and gpu fans continue running.
Where do I start to debugging this scenario? Should i jump straight to bread boarding?
strider87
I just tried the paper clip test on my PSU alone, however I noticed it turns on regardless of whether or not i connect the green and black pins, so as long as the PSU is on, any connected fan will run
