Hello,
I am having troubles with the new system I put together. I have disconnected the mouse, keyboard, hard drive, and dvd drive. I have also tested different memory and video cards. The same issue keeps happening though.
I press the button to turn on the power and the PSU turns on and all the fans including the CPU and video card fans work correctly. However, the motherboard makes no beeps or gives any sign that POST is occuring. The monitor goes into sleep mode immediately. Pressing the power button on the front of the case does not turn off the machine either.
I am not sure what the issue is. If I did something wrong or if some part is broken.
System:
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core
Rosewill Green Series RG630-S12 630W
EVGA 01G-P4-2650-KR GeForce GTX 650 1GB 128-bit GDDR5 PCI Express 3.0 x16
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
System:
