[New Build] First Home Build, Opinions?
Case: Rosewill Thor V2 ATX Full Tower ~~ $129.99
CPU: Intel Core i5-3570k Ivy Bridge 3.4GHz ~~ $219.99
HD: Western Digital WD RE4 500gb 7200 RPM ~~ $99.99
GPU: ASUS GTX650TI GeForce GTX 650 Ti 1GB PCI Express 3.0 x16 ~~ $159.99
PSU: Seasonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready ~~ $89.99
RAM: GSKILL Ripjaw Series 8GB (2 x 4GB) 240 Pin ddr3 ~~ $44.99
MOBO: GIGABYTE GA-Z77X-UP4 TH LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX ~~ $184.99
CD Drive: LITE-ON Black 4X Blu-ray Reader SATA Model iHOS104-06 - OEM ~~ $24.99
Total Price: $954.92 (on a slight budget)
Any Opinions are welcome as well as suggestions. Thanks
6 answers Last reply
More about build home build opinions
  1. the case is too costly..go for something around 75$..here a build for your budget..you can add a ssd if you want
    PCPartPicker part list: http://pcpartpicker.com/p/uTMJ
    Price breakdown by merchant: http://pcpartpicker.com/p/uTMJ/by_merchant/
    Benchmarks: http://pcpartpicker.com/p/uTMJ/benchmarks/
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Amazon)
    Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.98 @ Outlet PC)
    Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($35.57 @ NCIX US)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
    Video Card: Gigabyte GeForce GTX 660 2GB Video Card ($217.55 @ Newegg)
    Case: Corsair 300R ATX Mid Tower Case ($69.99 @ Newegg)
    Power Supply: Antec High Current Gamer 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($69.99 @ NCIX US)
    Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.98 @ Newegg)
    Total: $843.02
    (Generated by PCPartPicker 2012-12-29 21:04 EST-0500)
  2. I chose the case based on the fact that it is well equipped for future upgrades like water cooling, etc.
    Also, for an ssd, would this work? its the same exact price on Newegg
    --SanDisk Extreme SDSSDX-120G-G25 2.5" 120GB SATA III Internal Solid State Drive (SSD)
    There are plenty of cheaper cases for your purpose..ssd is fine
  4. You should be able to find a 1TB HDD for around the same price as ur current HDD, where are u purchasing from?
    Ok I'll look around. Though as the case is the only thing I am doing to the build in terms of looks, I might just keep it and go over budget. As long as the case won't cause any problems, I'll just hold onto it.
    Thanks a ton for the input
    Getting all the parts from Newegg. Checked out the prices on pc part picker or whatever that website was and ordering all the parts from different places only saved me about $15.00. Also, I'll try and find a 1TB HD for the same price.
    Also found this
    -- SanDisk Extreme SDSSDX-120G-G25 2.5" 120GB SATA III Internal Solid State Drive (SSD)
New Build Systems
