Will this build all work together?
Last response: in Systems
Anonymous
December 30, 2012 10:05:47 AM
Hi, I am going to be building a computer for the first time and have got all the parts set up in a basket, but I want to make sure they will work together. Can you guys please check this build and tell me if it will all work together?
Thanks
PSU - Corsair GS600 Gaming Series GS 600W ATX/EPS 80 PLUS Bronze PSU
HD - Seagate ST31000524AS 3.5 inch Barracuda 1TB GB 7200rpm SATA Drive with 32MB Buffer
Mobo - MSI 870A-G54 - Motherboard - ATX - Socket AM3 - AMD 870 - USB 3.0 - Gigabit Ethernet - HD Audio (8-channel)
GPU - Sapphire 11199-00-20G HD7870 2GB GDDR5 Graphics Card
RAM - Kingston HyperX DDR3 1600MHz CL9 8GB DIMM Memory Module (Kit of 2)
CPU cooler - Zalman CNPS9900-MAX Blue Ultra Aero Flower CPU Cooler Intel & AMD
Case - Zalman Z11 Plus Midi Tower Case (ATX, M-ATX, Supports Bottom PSU Installation and Aperture for Cable Management, Anti-Vibration Rubber Stand)
CPU - AMD HDZ965FBGMBOX Phenom II X4 965 - 3.4 Ghz AM3 Black Edition CPU, Retail Packaged
Will these parts work together and if so are there any other parts I will need?
Thank you in advance
More about : build work
December 30, 2012 10:52:31 AM
depending on what your budget is we might be able to help you build a better one
December 30, 2012 5:27:18 PM
It will work but I wouldn't purchase that case or power supply. If you post your budget that will help to suggest parts.
Anonymous
December 31, 2012 2:40:15 AM
Thank you for your replies,
My budget is £750 pounds, hope this helps.
December 31, 2012 6:32:43 AM
For that budget you can do way better:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor (£162.74 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£25.45 @ Scan.co.uk)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard (£101.98 @ Dabs)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory (£30.60 @ Aria PC)
Storage: Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive (£67.99 @ Overclockers.co.uk)
Video Card: Sapphire Radeon HD 7950 3GB Video Card (£239.99 @ Overclockers.co.uk)
Case: Fractal Design Arc Midi Tower ATX Mid Tower Case (£68.95 @ Amazon UK)
Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£68.48 @ Ebuyer)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£12.98 @ Scan.co.uk)
Total: £779.16
(Generated by PCPartPicker 2012-12-31 08:32 GMT+0000)
If you don't want to overclock:
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor (£144.00 @ Amazon UK)
Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard (£71.00 @ Amazon UK)
Total: £729.44
(Generated by PCPartPicker 2012-12-31 08:34 GMT+0000)
