Will this build work?
Hi, I'm thinking of building a desktop (first time) So I want to make sure if these parts are compatible / will fit in the case. $450 budget build
http://pcpartpicker.com/p/v4SD
I don't need a video card because I have a 9800GT already.
Thanks.
2 answers Last reply
More about will build work
  1. It will all work
    Suggestions though
    The Rosewill challenger won an award from Tomshardware for being cheap . The best case under $50 , but they commented on how thin the metal was
    I think the Antec ONE
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129181
    , and the CM 431
    are both better cases at that price point
    This Adata RAM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820211457
    is better and cheaper
  2. Alright thanks. I also chose the case for the fans. I'll swap out the ram too ^^
    Pcpartpicker lists the ram as incompatible o_O
Homebuilt Desktops Build Compatibility Systems Product
