Solved
Will this work? 1st Pc Build
PCPartPicker part list: http://pcpartpicker.com/p/v7o3
Price breakdown by merchant: http://pcpartpicker.com/p/v7o3/by_merchant/
Benchmarks: http://pcpartpicker.com/p/v7o3/benchmarks/
CPU: Intel Core i5-2500K 3.3GHz Quad-Core Processor ($209.99 @ NCIX US)
Motherboard: Gigabyte GA-Z77X-UP4 TH ATX LGA1155 Motherboard ($174.99 @ NCIX US)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($44.99 @ Newegg)
Storage: Western Digital RE4 500GB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Adorama)
Video Card: Asus GeForce GTX 560 1GB Video Card ($149.99 @ Newegg)
Case: Rosewill THOR V2 ATX Full Tower Case ($129.99 @ Newegg)
Power Supply: SeaSonic 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($88.53 @ Amazon)
Optical Drive: Lite-On iHOS104-06 Blu-Ray/DVD/CD Drive ($24.99 @ Newegg)
Total: $913.46
(Generated by PCPartPicker 2012-12-31 02:40 EST-0500)
5 answers Last reply Best Answer
More about will work build
  1. Best answer
    Dear cu1993,
    That build would work, but with three suggestions: upgrade to i5-3570k, as it is much better than the 2500k (unless you want to overclock), but if you are, then get a cm hyper 212 evo, they work great for O/C. Also, you should try this HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822236338, it's a caviar blue, but it still works great and you get 250GB more space and SATA 6GB/S, which is almost twice as fast for the same amt. of money (according to Newegg). Finally, you should get a lower wattage power supply (unless you are O/C). I would recommend Corsair's builder series http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027. You can still upgrade and/or get a decent overclock out of it.
    Good Luck! :)
  2. you should try for hd7850 which is available for 165$ and is much better than gtx560
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161426
    http://www.anandtech.com/bench/Product/549?vs=543
  3. check this build out its better
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Amazon)
    Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.98 @ Outlet PC)
    Power Supply: Antec Basiq Plus 550W 80 PLUS Certified ATX12V Power Supply ($64.99 @ Newegg)
    Total: $859.89
    (Generated by PCPartPicker 2012-12-31 07:52 EST-0500)
  4. Thanks for all the replies!
  5. Best answer selected by cu1993.
New Build Systems Product
