Archived from groups: alt.cellular.nokia (More info?)
Hi all
Just subscribed as i know u exist but never been here before.
I have a Nokia 7270 and have a usb dku data cable
This cable worked fine on my 7200 but in recent times wouldnt connect saying
'data enhancement not supported'
I am trying to connect my 7270 using the same cable and getting the same
error message
is the cable knackered? or is there something else i need to do.
I have downloaded the driver updates etc.
On Sat, 19 Feb 2005 18:45:26 GMT, "Treb" <Treb@blueyonder.co.uk>
wrote:
>Hi all
>error message
>thanks
>Treb
which dku cable do you have? the 7270 uses the dku-2 whereas the 7200
uses the dku-5.
good point, not actually sure
maybe i'll buy the other as this one used to work with the 7200
cheers mate
Trebble
"eggster2k" <eggster2k@nospambreathe.com> wrote in message
news:hfkg111cqc6n2olcclklffb13dvo22et1d@4ax.com...
> wrote:
>>Hi all
>>saying
>>error message
>>thanks
>>Treb
> uses the dku-5.
