Closed Solved
Gtx 650 power supply
i need advice if a gtx 650 will work on a cooler master eXtreame 460w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171028
13 answers Last reply Best Answer
More about power supply
  1. No. That's too bad of a PSU. I wouldn't risk it.
    EDIT
    On the other hand, what's the rest of your system?
  2. That PSU must be called Coolercrap.
    So whats ur budget ?
    U can get maybe a Cx 430 or a good 500-550 W Psu
    EDIT
    the rest of the Planned system is
    Phenom II 965 x4 AM3
    Asrock or Asus Amd 970 series motherboard (not sure which one yet)
    16 gb DDR3 ram xm3 corsair
    have a dvd rw cd rw combo thingy by LG
    no liquid cooling of any sort
    4 led 120 mm fans
    as for my budget $50 is the max i can go ... hopefully
    EDIT:- the only reason i bought the power supply that i have now is because it was free at black friday last year
  4. prototype18 said:
    even though that is a great price i really can't see the system going over 250 watts . .
    CORSAIR Builder Series CX500 $57.99
    Save: $12.00 (17%)
    $37.99 after $20.00 rebate card
    i was going to post the CX430 but that is just $3 more after MIR.
  5. could i go a bit cheaper than that? i am really tight on budget and again 50 is the very limit of what i had in mind
  6. Best answer
    well then
    CORSAIR Builder Series CX430 430W $44.99
    Save: $5.00 (10%)
    $34.99 after $10.00 rebate card
  7. Anonymous said:
    well then
    Save: $5.00 (10%)
    one quick other thing there are 2 editions of the same graphic card. one is an overclocked edition. can't we overclock the regular one ourselves to match the other one
  8. Sure u do . But to be 100% sure link them to us.
  9. ok thanks guys for the help i will be starting to look for the cx 430.
Graphics Cards Gtx Cooler Master Power Supplies Graphics Product
