Would it be possible to use 3 molex splitters to power 2 6 pci cables
- Can i use molex splitter to power up ( molex to 6pin PCI adapter) - Forum
- Using 2 PCI-E Power Cable Splitters on Corsair VS650 - Forum
- Can I use a 2 molex into 6 pci cable having a GPU (GTX 650ti Palit)? - Forum
- No 8-pin pci-e on my power supply... should I use 6 pin or 2 molex? - Forum
- PCI-E 6-pin to 2-Molex Power Y-Adapter Cable Keeps burning - Forum
- is it possible to use a 4 pin molex to 6-pin pci in this scenario Forum
- Solvedcan(should) i use a molex splitter then a molex to 6pin to supply power to my HD 4870 Forum
- Solvedpci-e 6 pin power to 2 molex? Forum
- SolvedUsing two 2-molex to 8-pin pci-e adapters to power Gigabyte GTX 770 4gb Forum
- 2 molex to 6 pin pci e y-cable enough for n260gtx? Forum
- SolvedOne of my PSU cables has both SATA power and Molex on the same cable. Can I use it to run my HDDs AND fans? Forum
- SolvedUsing one of two molex cables to power my GPU? Forum
- Solved650ti Boost 2x4pin molex to 6pin pci-e Forum
- SolvedCan an 8 pin (type 3) cable plug into an 6+2 PCI-E port? Forum
- SolvedInstalling GTX 770: Can I use a 6+2 PCI-E cable on a 6 pin socket? Forum
- Would i be able to power a 6870 using a 2molex to 6pin adapter Forum
- SolvedASRock Z77 Extreme6 1155 - Molex PCI supplemental power Forum
- SolvedCan I use one 4 pin molex to power a 6 pin graphics card (nvidia GeForce gtx 650)? Forum
- SolvedSimple graphics card cable question. Two 6pin-6pin cables or one 6pin-2x6pin splitter? Forum
- SolvedDifference between using PCI/E power cable to connect to GPU v/s peripheral power cables Forum
- More resources
