Problems diamond radeon hd 6670 card GDDR5
  • Diamond Multimedia
  • Diamond
  • HD
  • Radeon
  • Graphics
November 17, 2012 5:56:11 PM
display continues to flicker when more than one window open. Incomplete text on web pages, stalled video,
AMD 3.4 Gz Phenom II
Win 7 Ultimate
Gigabyte MB 790FX
16 gb ram
750 w power
Diamond Radeon HD 6670 GGDR 5 card
Updated drivers and BIOS
Samsung synchmaster display
More about : problems diamond radeon 6670 card gddr5
November 17, 2012 6:50:50 PM
Artifact problem..
check your fan if it still spinning when operate..
Reapply your thermalpaste with a good thermalpaste..
and
Try to check your gpu temperature with gpuz or msi after burner..
What i your psu? (but i think since it's a 750 w psu, it would not be a problem..)
____________
If you have done the above steps and problems still occur, then your card may have been damaged..
if your card still covered by warranty, rma your card..
if your card out of warranty, then let's do something a little extreme
try to wash and bake your gpu..:)
m
l
November 17, 2012 9:59:43 PM
Thanks for the reply. looks like I will need to dig out my registration data and send this one back in!
quotemsg=2845779,2,709609]Artifact problem..
and
____________
try to wash and bake your gpu..:) [/quotemsg]
m
l
