I am building a brand new pc (specs below) and I was just thinking. I ordered one intel 520 240gb ssd and I was wondering if I should order another and put them into Raid 0 with two. Would this be a good idea? I hear they don't have trim yet? or maybe they do now. But I am not sure what that is. Will running two 520's in raid0 lower there lifespan dramatically? basically should I go for it or stick with the single 520 240gb?
Case: Antec Darkfleet 85 | http://tinyurl.com/38fbwxu
CPU: Intel Core i7 3770K Unlocked Quad Core Hyperthreading LGA1155 3.5GHZ | http://tinyurl.com/bv3s4e8
CPU cooler: Corsair Cooling Hydro Series H100I | http://tinyurl.com/d24vrnv
Mobo: ASUS Sabertooth Z77 ATX LGA1155 | http://tinyurl.com/bwhlosu
SSD: Intel 520 Series 240GB 2.5in SSD MLC 25nm SATA3 Solid State Disk Flash Drive OEM | http://tinyurl.com/cl94umy
PSU: Seasonic X850 Gold | http://tinyurl.com/chr3s93
Memory: Mushkin Enhanced Blackline Frostbyte PC3-12800 16GB 2X8GB DDR3-1600 9-9-9-24 1.5V | http://tinyurl.com/cxx4c8v
Video Card: ASUS GeForce GTX 680 DirectCU II 1006MHZ 4GB GDDR5 6GHZ PCI-E 3.0 | http://tinyurl.com/d9by7rv
Sound Card: ASUS Xonar Essence STX PCI-E1 SPDIF Sound Card 124DB SNR | http://tinyurl.com/c8eaz9s
