I got some good suggestions in my last post about GPU's and finally came into two suggestions... the HD 7850 or the GTX 660 (Both 2GB versions)
What exactly do you guys recommend?
For the 7850 only the Sapphire version is available
For the GTX 660 only the Axle version is available
According to this site, the GTX 660 is better in most of the reviews.
http://www.anandtech.com/bench/Product/549?vs=660&i=372.373.375.376.378.379.381.382.384.383.387.388.390.392.394.396.400.398.401.403.404.457.456.460.391.426.406.424.407.411.410.422.423.409.413.412.414.415.416.417.418.419.420.421
What should I go for? I have never used AMD GPU's...Is it better to get the Axle GTX 660?
