I'm building a comp, but have a dilemma, please help.
  • Homebuilt
  • Systems
  • Product
Last response: in Systems
January 3, 2013 11:22:29 PM
I have order parts on newegg, but people keep telling me that what I have ordered is not good for a gaming computer. my parts are
http://www.newegg.com/Product/Prod [...] 6811129066 =computer case
http://www.newegg.com/Product/Prod [...] 6813131758 =motherboard
http://www.newegg.com/Product/Prod [...] 6820134928 =memory
http://www.newegg.com/Product/Prod [...] 6819113286 =processor
http://www.newegg.com/Product/Prod [...] 6827151256 =dvd rom
http://www.newegg.com/Product/Prod [...] 6817182261 =power supply
http://www.newegg.com/Product/Prod [...] 6814130623 =graphics card
http://www.newegg.com/Product/Prod [...] 6822145299 =hard drive
http://www.newegg.com/Product/Prod [...] 6817994085 =hard drive mounting bracket
I will be running all of this with windows 7.
Now I may be able to cancel the order, though I already own the graphics card. So can someone very experienced please give me a 400 dollar budget for everything besides the operating system and graphics card that will be the best gaming comp it can be for the price? Thank you, I really appreciate it.
More about : building comp dilemma
a b B Homebuilt system
January 4, 2013 12:20:48 AM
All of your links are broken. Please verify these are the components you have purchased:
Case: Antec Three Hundred
Motherboard: ASUS M5A88-M AM3+ AMD 880G HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
Memory: Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066
Processor: AMD FX-6300 Vishera 3.5GHz
DVD ROM: SAMSUNG DVD Burner
Power Supply: Rosewill CAPSTONE Series CAPSTONE-450-M 450W
Graphics Card: EVGA GeForce GTX 560 Ti
Hard Drive: HGST 500GB 7200 RPM
Bracket: BYTECC Bracket-35225 2.5 Inch HDD/SSD Mounting Kit For 3.5" Drive Bay or Enclosure
If these are the components you've actually ordered, then here are my thoughts:
Most people are going to recommend an Intel Core I3 processor over any AMD processor for a gaming system. According to Tom's Hardware Best Gaming CPU for the Money - December 2012 article, they would be correct for a strictly gaming system. If you do anything else on this system, then I, personally, would recommend the AMD FX-6300 at this price point.
I would look at getting faster RAM. Your motherboard accepts up to DDR3-1333 RAM, so spend the extra dollar or two on it.
Unless I'm mistaken, Rosewill is the house brand for Newegg (like Dynex is the house brand for Best Buy). The reviews are excellent thus far, but for the price, I'd probably stick with a power supply from a company a little more proven, like Antec, Corsair, PC Power and Cooling, Seasonic, or FSP (Fortran Source).
Unless you intend to add a 2.5" SSD in the future, there is no need for the HDD bracket.
-Wolf sends
FYI, the correct coding for links within threads is as follows:
  1. [urlExt=http://www.newegg.com/Product/Product.aspx?Item=N82E16817182261]Rosewill CAPSTONE Series CAPSTONE-450-M 450W[/urlExt]
Which will appear in your post as: Rosewill CAPSTONE Series CAPSTONE-450-M 450W
Note the location of opening and closing brackets ( [] )
Edit: I'd also note that your motherboard will likely require a BIOS upgrade in order to utilize that processor to it's fullest extent (or at all).
