Help finding power supply
Last response: in Systems
Hello,
I am a first time computer builder and I have already built the computer and so far everything works, components are as follows:
Intel Core i3 3220 @ 3.3 Ghz
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Mode
BIOSTAR H61MGC LGA 1155 Intel H61 Micro ATX Intel Motherboard
Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
MSI DVD Burner 24X DVD R 8X DVD RW 24X DVD-R 8X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DH-24AS U88
MSI R6850 Power Edition 1GB GDDR5
APEVIA ATX-CB700W 700W ATX12V / EPS12V SLI Ready CrossFire Ready Power Supply - OEM
Now I know that the PSU is terrible and that is what I want to replace, so I need some options on a PSU that will be good for my build. My budget is less than $100 and it would take me a while to build up the money. Any opinions would help. Thank you!
More about : finding power supply
Related ressources
Homebuilt system Expert
If you've already got that Apevia in your build and you aren't experiencing any problems, I wouldn't bother replacing it. Especially if you are low on funds. Your setup is not terribly power hungry, so even if that thing is giving 2/3 of the rated power, you'll be fine.
Homebuilt system Master
^ I think hes more concerned with the quality of the PSU than its wattage.
APEVIA has a pretty horible reputation, its not 80+ Certified nor does it have Active PFC. According to its specifications it can only put out 588W on the 12v (which is the only rail of importance really, it powers the CPU, GPU, Mobo/RAM and anything connected to a Molex)
Besides, a 700W for $40 isnt to be trusted.
Something else will be on sale in a few weeks, so it's best to check when you have the money. XFX is great, but Antec and others go on sale regularly, too.
If the old one is working, you could probably get $20-30 on ebay for it. Not everyone cares enough to buy a good PSU.
