Hello, first off this is my PC specs:
MSI Z77A-G43
Intel Core i5-3570K
8GB Corsair Vengeance RAM
HIS HD7850
Sapphire HD7850
500GB Hitachi HDD
OCZ ZS750W PSU
and case doesn't make a difference
My problem is that, when using both graphics cards, only one of them has 'usage' on it, and the other card is idle, both cards have drivers installed and crossfireX is enabled, but even on Minecraft (this was the only game at 1920x1080 that my PC struggled with) at absolute max settings with everything turned on I was getting only around 20FPS and the second card was idle 95% of the time. How would I get both cards to share the load evenly, or even get the second card to spring into action when I need it. I plan on running a triple monitor setup, 5760x1080, would this cause both cards to run at max load on a demanding game, or once again will only 1 of them work and struggle? I'm confused.
Thank you.
MSI Z77A-G43
Intel Core i5-3570K
HIS HD7850
Sapphire HD7850
500GB Hitachi HDD
OCZ ZS750W PSU
Thank you.
