Closed Solved
Graphics Card Help!
Hey all,
Just got a free machine off my dads friend; opened it up last night and found:
Asus P5B Premium Motherboard
Intel Core 2 duo Quad Q6600
8 GB of Corsair DDR2 Memory
Power supply etc.
No graphics card though - I am looking to grab a 1GB graphics card for relatively cheap (60)
It's a PCI Express slot.
Looking to turn this machine into a gaming computer to play Skyrim etc.
Any ideas?
12 answers Last reply Best Answer
More about graphics card help
  1. What size is the PSU? $60 is hardly enough for real gaming.
  2. +1^
    and what resolution is your display?
  3. mdkrs said:
    Hey all,
    Power supply etc.
    Any ideas?
    please answer all the questions below.
  4. The PSU is OCZ technology - 700 watt power rating :??:
  5. clutchc said:
    +1^
    not sure about this, the computer has no vid card - haven't even turned the thing on.
  6. I have a offer on kijiji for a ASUS Radeon 5670 1G GDDR5 for 60 bucks..
    Looking at Canada Computers and they have cheaper 1 gb video cards like the sapphire for 30 quit.
    I am a newb at this :)
    That doesn't matter. What is the resolution of your monitor or HDTV you are using?
  8. its a dell:
    1280 x 1024 at 75 Hz
  9. HD5570-HD6670 should handle that well.
  10. Best answer
    I agree with boyabunda... here is that same card on the Canadian Newegg site if it makes a difference for you:
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814131440
    It will be more than enough to game with near max settings and great frame rates at 1280x1024 and higher. I have a Gigabyte HD 6760 1GB I'm using in a new budget build. It can even game at 1920x1080 with reduced settings.
  11. Best answer selected by mdkrs.
Graphics Cards Graphics Product
