Hello there!
I've been using a Radeon HD 6850 Black Edition Graphics card for a dual monitor setup for a while, my initial two monitors are both connected via DVI. I recently purchased a third monitor and attempted to hook it up. (I'm attempted an Eyefinity Setup) My Card only has 2 unoccupied ports; Display Port and HDMI. I've attempted using both Display Port and DVI and am unable to get windows to recognize anything but the first two, and sometimes the 1st and 3rd monitors. When I open up the Catalyst Control Center, I find the following.
Upon clicking the triangle on the third, unnumbered Display shown I get the following options
-Extend
-Replace
When I hit Extend I get the Message "To Extend this Display must be Disabled"
Upon Hitting continue I find that the screen disappears from the Control center all together
(Please note upon hovering over the third screen, it shows its disabled)
When I hit Replace I find the display is gone as well, with a box prompting me to disable another screen.
I'm unsure if I need to purchase another card, or if I'm missing something very obvious; but I can't seem to get all 3 displays on at the same time, I've followed plenty of tutorials on how to get 3 displays going, all resulting in failure.
If you have any idea on a fix, I'd love to hear it!
Kind Regards
-Bubble
E: Upon visiting the Eyefinity section, I find
When I hit Identify All, it simply identifies the 2 current screens being displayed.
In addition, I can make any combination of 2 screens appear, so the cables and ports are functioning.
-Extend
-Replace
Kind Regards
-Bubble
